water pump replacement
Old Jan 30, 2011 | 07:15 PM
al1989's Avatar
Engine: 305 5.0 L
Need to replace the the stock water pump off my 1989 RS Camaro it has a 5.0L 305 engine. Now whats the diffrent between a short or long water pump and do you think I sure replace it with and eletric pump instead?
AL1989
Old Jan 30, 2011 | 07:30 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: water pump replacement
If it is street driven or daily driver I do not recomend an electric pump. where are you looking for a pump? our pumps are unique and usually arent called long or short. Usually they are classified as serpentine belt pumps, or reverse direction pumps. Like an edlebrock pump part # 8881 Or Summit # EDL-8881. Any local parts store should have a NEW pump for you to get. Around 40 dollars.
Old Jan 30, 2011 | 07:35 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
'89 5.0 engines use a reverse rotation "long"water pump
Most '69-'87 use standard rotation"long" pump,the
"short"pump is used on most '68 earlier and has a
smaller bearing.
Stock '88 up reverse rotation pumps have a different
pulley bolt pattern than '87 earlier pumps,but
apparently some aftermarket pumps have hubs with
both bolt patterns, and using the wrong rotation pump
has caused some cooling problems on here-pumps
pump water badly(but in the same direction)when
turning wrong rotation Some on here have reported
good results using electric water pumps for street
and even highway use,but it usually is not a good
idea.
Old Jan 30, 2011 | 07:49 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Glad you chimed in as you obviosly know a little more about it than me. good work.
Old Jan 30, 2011 | 08:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
http://www.autozone.com/autozone/par...7_193803_6245_
Old Jan 30, 2011 | 08:22 PM
Flightoficarus's Avatar
Yeah, just go down to a parts store and pick up a stock pump. There should only be one "reverse rotation" type pump for the serpentine belt equipped V8's.
Old Jan 31, 2011 | 09:28 PM
al1989's Avatar
Engine: 305 5.0 L
Thanks for all the response if a regular factory water pump works fine than so be it.
al1989
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
