3rdgen single fan questions
Old Feb 8, 2011 | 12:51 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
How many amps does it draw and how much CFM does it move?
This is all i want to know.
Old Feb 8, 2011 | 01:10 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: 3rdgen single fan questions
about 20 amps on startup
about 900-1000 CFM
These things are also subject to wear however.
Mine got to the point where it burned 30 amp fuses and gave off 0 CFM
Old Feb 8, 2011 | 09:36 PM
FueledSoul's Avatar
What's the constant draw when it's running?
Old Feb 8, 2011 | 09:59 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Eh probably somewhere between 12-18 amps. You should really upgrade to dual fans if you can. I'd suggest LT1 or LS1 fans...
Old Feb 8, 2011 | 10:54 PM
FueledSoul's Avatar
Thanks.
I already made my own dual fan set up for the 3rdgen, Its a lot better then the 4thgen fan setups. The 3rdgen single fan might be going on my blazer with an adjustable fan controller.
krisner89
Oct 10, 2015 06:03 AM
fasteddi
Sep 2, 2015 10:29 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
