cooling problem
Old Feb 9, 2011 | 12:58 PM
Wolfman720's Avatar
Car: 1985 Trans am/1999 TT vette
Engine: 305/LS2
Transmission: 700R4/T56
Axle/Gears: stock
cooling problem
hey guys. new to this site. i just picked up an 85 TA. LB9. it overheats around town. stay right in the 220 range on the highway.
thermostat is opening. lower hose isn't collapsed. fluid level is ok. air damn is intact. nothing blocking the radiator.
is it safe to assume the fan is the issue (electric fan)? is this a common issue?
Old Feb 9, 2011 | 01:05 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: cooling problem
Could be the fan or the the coolant temp sensor that tells your fan when to turn on.....
Old Feb 9, 2011 | 01:06 PM
Wolfman720's Avatar
Engine: 305/LS2
Axle/Gears: stock
Re: cooling problem
hmmm....where is that sensor?
Old Feb 9, 2011 | 01:11 PM
Re: cooling problem
There is one on the block and one by the thermostat. One tells the fan to come on and the other is for your gauge on the dash. I forget what one of the 2 tells the fan to come on. Search: coolant temp sensor whithin this site.
Old Feb 9, 2011 | 01:27 PM
Re: cooling problem
I have changed both of mine but that was a year ago and forget. But I believe one is called the "coolant temp sensor" and the other is called the "coolant temp switch" Try direct wiring your fan to the bat. if it comes on then it should be your sensor........
Old Feb 9, 2011 | 03:11 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: cooling problem
When sitting in the driveway idling, does the fan come on when you turn on the AC? If so then at least you know the fan and relay are OK
Old Feb 9, 2011 | 05:49 PM
Wolfman720's Avatar
Engine: 305/LS2
Axle/Gears: stock
Re: cooling problem
i didn't think of the AC thing. i'll try that out tonight. thanks
Old Feb 10, 2011 | 07:48 PM
Wolfman720's Avatar
Engine: 305/LS2
Axle/Gears: stock
Re: cooling problem
ok, the fan is bad. any specific replacement you guys recommend?
Old Feb 10, 2011 | 08:15 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: cooling problem
just a replacement fan is fine. rockauto.com might have what you need. if its just the fan motor not the fan you can go to autozone and pick a motor up. also check under your car for the black air scoop for your car
Old Feb 10, 2011 | 09:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: cooling problem
If the fan didn't go on with the AC, the fan may still not be the problem. Could be the relay or wiring. Make sure you test by putting 12 volts to the two motor contacts before you just replace it.
Old Feb 10, 2011 | 09:08 PM
Re: cooling problem
agreed
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
chazman
Aug 22, 2015 02:01 PM
