A/C Help
Old Feb 10, 2011 | 07:11 PM
Bamapoet's Avatar
A/C Help
I have a 2000 Camaro with the 3.8 V6 and I have a question about the A/C. I bought the car used with the A/C not working. I replaced the compressor, drier and orifice tube then I thought I had cleaned the system well using alcohol and compressed air but the compressor locked up ten minutes after adding freon. I removed the orifice tube and found it clogged with powdered aluminum. Ok, here's my question. I plan to replace the condenser, compressor, drier, orifice tube and all lines/hoses. Since I've heard it's such a difficult task, can I just flush the evaporator core and if so could someone please tell me about doing this and what to use to flush it? Thanks guys!
Old Feb 11, 2011 | 12:09 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Feeling Flush
Yes, flush away !
Auto parts stores carry pre-mixed flush solutions or kits to speed up the pit stop.
When you were fixing the old system, you didn’t say you added oil.
Don’t forget it.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
