how to run Dual Fans on a OEM Single fan setup
Old Feb 14, 2011 | 05:49 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
i found these dual fans on a '92 trans-am thats being parted out it has the connections on it but how would i run those dual fans in place of my single fan setup help
Old Feb 14, 2011 | 06:33 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: how to run Dual Fans on a OEM Single fan setup
The preferred method is to study the wiring diagrams for the Z/28 / IROC-Z dual fan factory wiring circuit, and incorporate that into your car's harness. That way (if you're running a stock ECM) their function will be automatic. The other options are to purchase a fan controller and wire them to be controlled by it, or wire them directly to switches and run them manually. Fan wiring is actually pretty simple, so don't get overwhelmed if you aren't very familiar with electrical stuff. If you can read a wiring diagram (Haynes diagrams are pretty easy to read), use a multimeter and take a low volts DC and ohm readings, then you'll do ok.
Old Feb 14, 2011 | 07:33 PM
one92rs's Avatar
Car: SOLD!!!!!
if your car came with a single fan then the ecm does not have provisions to run the fans. it is turned on by the temperature sender for the fans. you could add a relay or two and have them come on with the same temperature switch though. i put duel fans on my rs ( 4th gen fans) and i used a flexalite controller to control them.
Old Feb 14, 2011 | 09:28 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I put 4th gen fans. and just tapped into the wiring for the single fan. with another connector and I am running good for years!
Old Feb 14, 2011 | 11:50 PM
kcb37's Avatar
I would agree, you can run them together off the single fan setup.
Or the easiest would probably be to just get an aftermarket contorller.
Or use the stock setup for one fan, and run the second off a second temp with an aftermarket controller.
Old Feb 15, 2011 | 10:55 AM
DiabloWS6's Avatar
i was looking at wiring diagrams at school for my '86 t/a and the dual fans from the '92 t/a and it is possible to splice the duals in place of my single fan and replace the in-line fuse but some class mate asked me a very good question what is the benefit of running to small fans instead of the single large one i never really saw it like that beacuse both the fans are stock for both cars
Old Feb 15, 2011 | 07:38 PM
The two small fans actually move more CFM than the single fan, and cover more square inches of the radiator. As for wiring, you can replace the single fan with the duals and have the ECM still control them, it just wouldn't have staged control (both would operate at the same time). Just make sure to run each thru a separate relay and fuse, with separate 12V feeds on at least 12 gauge wire each to supply adequate current without fear of overtaxing a circuit.
Old Feb 15, 2011 | 08:46 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
precisely the dual fans cover more of the radiator so you get more airflow and better cooling
Old Feb 17, 2011 | 01:33 PM
DiabloWS6's Avatar
thanks for youre help if i have any more questions ill keep u guys posted
Old Mar 30, 2012 | 07:50 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Old post, but did you have to put a bigger fuese in or use different relays? Just curious because I"d like to do this over the summer since my single fan doesn't cool enough with the AC on.
Old Mar 30, 2012 | 09:14 AM
crazymonkey16's Avatar
Car: 1990 Camaro RS
Engine: L05 TBI
I assume you're wiring two fans up as if they were one fan? In that case, I'm not sure if you *need* another relay, but when I put my fans in that way, I put both fans on seperate relays just in case. It wasn't too expensive, not really much extra work, and it's worked fine so far. *shrug*
Old Mar 30, 2012 | 12:46 PM
L.A.KR-1's Avatar
Car: 1991 pontiac transam
Engine: 5.07 tune port fuel injection
temperature sender
h hey..do you know..the exact place where the temperature sender..sensor..(right) its located in a 91 pontiac transam..my fans not working so good.. you have some pictures..of this..
Old Mar 30, 2012 | 04:46 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
When I installed my dual fans I duplicated the factory single fan setup by getting a factory style relay connector from tpiparts.net. Then I bought a factory style relay, tapped off the trigger wire that goes to the original relay, and copied the wiring for the new relay connecor like the original. I mounted the new relay basically in front of the old relay.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
customblackbird
Aug 15, 2021 10:16 PM
onefreakz
May 14, 2018 12:15 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
