Canton fabricated coolant tank.
Old May 11, 2011 | 08:22 PM
  #51
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Canton fabricated coolant tank.
Originally Posted by cc 82Z-28
I got mine off ebay as well last year, I really like the look over the plastic bottle.
if only they make a matching washer reservoir too
Old May 11, 2011 | 10:25 PM
  #52
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I just ditched my washer bottle. If it gets bad I will just stop at a gas station and use a squeege. And I just ordered my Canton 2 days ago, they make good stuff. I also have their 7qt road race oil pan.
Old May 12, 2011 | 02:10 AM
  #53
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Ordered mine today, already have their lt1 valve covers.
Old Jul 13, 2011 | 12:10 AM
  #54
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
i really dont want to run a coolant tank upfront i have a plastic one hidden by my foglights. any one used these before ?
http://cgi.ebay.com/ebaymotors/2x10-...Q5fAccessories
Old Jul 16, 2011 | 03:37 PM
  #55
IrocZ'85's Avatar
Car: '85 IrocZ
I'm looking for a good alternative too, if you get it let me know how it looks and how well it works
Old Jul 19, 2011 | 12:06 AM
  #56
91 1LE's Avatar
Car: '91 1LE
Cheap, Chinese junk. They work but I would rather pay more for a part made here.
Old Jul 19, 2011 | 08:27 AM
  #57
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Check the fabrication board. A member over there made washer and overflow from pvc and mounted it down there.
Old Jul 21, 2011 | 07:09 AM
  #58
IrocZ'85's Avatar
Car: '85 IrocZ
yes I believe that was FueledSoul and it was a very nice diy writeup and finished product...i might just do that
Old Feb 28, 2012 | 01:07 PM
  #59
87350IROC's Avatar
Car: 87' IROC
Just to let you guys know. Canton now sells these with vented caps. You can also buy the vented cap separately for those that need one. Their new style cap also looks better.
Old Feb 28, 2012 | 06:29 PM
  #60
87350IROC's Avatar
Car: 87' IROC
Old Feb 28, 2012 | 07:05 PM
  #61
//<86TA>\\'s Avatar
Car: 86 Trans Am
i like that much better!
Old Jan 19, 2017 | 07:00 PM
  #62
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Any else purchased one of these recently? I just got mine, drop shipped from Canton. Threw in 2 bolts and I don't think it's anywhere close to where it's supposed to be. I don't think even elongating the holes 1/4" or so will straighten it up. For the price, I really don't feel I should have to modify it to fit.
Old Jan 22, 2017 | 10:33 AM
  #63
Twin_Turbo's Avatar
It's crooked indeed. Do you have the lower bolt in? Looks like there's nothing there. All the holes are slotted, you should be able to move it about a bit.
Old Jan 23, 2017 | 03:13 PM
  #64
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Yeah, there's a long bolt in both the holes, but no nuts on the back side. One bolt is silver, one is black, so it's hard to see. Adding nuts would pull it tight but in the same spot as pictured.
The slots don't allow much movement. Even if I made them bigger, it's just that far off.
I received an email back from Canton. They're not sure what happened as it is welded on a jig, but would check with their QA/QC guys for ideas. Last thing I want to do is start to bend and modify it for them to say to send it back. It seems like that it's been a few years since anyone here has purchased one so I was just thinking they had a new jig or something.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
