Canton fabricated coolant tank.
Old Feb 22, 2011 | 09:25 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Anyone on here have one? Looks nice in the pics, but wondering how well it fits. It's supposed to be a direct fit in our cars. I would like to see pics if anyone has one.
Thanks!
Old Feb 26, 2011 | 03:04 AM
Re: Canton fabricated coolant tank.
Anyone? Someone has got to have one of these...
Old Feb 26, 2011 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If it's what I'm thinking of (alum), a friend had one in his thirdgen. He didn't like it for some reason and offered it to me. I didn't go for it as, IIRC, there was no provision to check coolant level. I purchased new GM plastic tanks, which look great--at least when they're new.
JamesC
Old Feb 26, 2011 | 07:15 AM
Twin_Turbo's Avatar
Old Feb 26, 2011 | 12:30 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
always check there web site for better deals. most of the time you can get there parts for half price or less..
will say it's big and Bulky.
other after market cans are of the 32oz size. more then enof. and can be fit down by the battery/ in front
Old Feb 26, 2011 | 03:35 PM
Twin_Turbo's Avatar
it's not bulky, it's smaller than the stock one
Old Feb 27, 2011 | 12:40 AM
Yep! Thats the one! I was wondering what it looked like installed. Looks pretty nice! I was thinking it might dress up the engine bay in my mostly stock IROC. I think I would install a couple 90 degree elbows and a piece of clear tubing to keep track of the level... Thanks for posting Guys!
Old Feb 27, 2011 | 08:10 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i had mine polished it is smaller you need to redrill 1 hole as the other will fit i just ended up drilling a small pin hole in the fill neck facing the firewall for it to breathe and just used some an line and fittings Name:  DSC00461.jpg
Size:  143.5 KB Name:  DSC00460.jpg
Size:  165.7 KB Name:  DSC00451.jpg
Old Feb 27, 2011 | 10:12 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
that is deffinately a nice piece to finish off a particular look. ill stick with my lighter plastic bottle tho
Old Feb 27, 2011 | 11:25 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have the same one, its a nice piece
FWIW, mine didnt come with a vented cap, which caused a pressure issue until i figured it out. I drilled a hole int he center of the fill cap, made a little baffle for the underside and all is well.
Old Feb 27, 2011 | 06:21 PM
Good to know there is a trick to getting it to work.
Twin_Turbo; Where did you get that radiator top mount? I am guessing you had it custom made, as I have the griffen radiator and have been searching for something like that.
Old Feb 27, 2011 | 06:30 PM
when set nexed to a slim 32oz size catch can. they are.. sorry
but they do replace the stock one..
they do look nice. got to give them that
Old Feb 28, 2011 | 10:01 AM
Twin_Turbo's Avatar
But where are you going to mount a universal tank without it looking like crap and having to drill holes? IMO it has a lot going for it that it's a direct replacement.
Old Mar 1, 2011 | 01:24 AM
FWIW: On their ebay site, Canton claims it is 2 oz lighter than the stock plastic bottle... It's a great alternative for me as I live in AZ and my Brand new plastic one (Yes, it's an actual GM part.) turned yellow in 3 months and I use red coolant! The extreme heat here kills plastic.
Twin_Turbo, how about that radiator mount? (Figured you missed it in the post above.)
Old Mar 1, 2011 | 03:53 AM
Twin_Turbo's Avatar
I made it, I have the 2nd "revision" on my red camaro with dimpled holes. It probably won't fit the griffen rad though. I posted a cad file in the custom fab thread so if you want to copy it, download that and take it to a sheetmetal shop
Old Mar 1, 2011 | 03:25 PM
Ah! Thank you for the info!
Old Mar 1, 2011 | 10:43 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
that is nice twin turbo and 2 oz is nothing to say wow about.
Old Mar 2, 2011 | 12:17 AM
LOL! I know: "WOW! A WHOLE TWO OZ!" Really shedding weight now! My point was that the plastic bottle isnt lighter...
Old Mar 2, 2011 | 03:36 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I know that. But I like it. So if I am ever in the market for a new bottle I will go ahead and get this one. I assumed the plastic was lighter.
Old Mar 2, 2011 | 07:11 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I bought the same one from a member here last year on the classifieds. My old tank must have had a crack somewhere because it would seep out slowly from the tank over a few weeks and I would find it empty even when the car had not ran.
I threw some ARP stainless engine dress bolts I had left over on it. One of my front tabs didn't want to fit flush with the mount. It actually was off by quite a bit. Still 2 ARP bolts with locking compound and a loc washer holding it down is more than enough
Good to know about the vent. Mine also is totally sealed I guess I'll drill a small hole in the top of the cap.
Old Mar 2, 2011 | 10:59 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
there are some reallllllly nice looking engine bays in this thread, i'm jealous
Old Mar 3, 2011 | 12:26 AM
I was thinking the same thing! *WHEW*
Old Mar 3, 2011 | 01:20 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Here's my overflow coolant tank, only problem is the cap tends to rott away quickly. Name:  PICT1149.jpg
Old Mar 4, 2011 | 12:12 AM
you do have a point... my bats in the back.. buffed out they look better also..nice job
Old Mar 4, 2011 | 02:58 AM
I'm thinking it'll go well in my IROC DD with polished plenum and runners
90-irocdx3; Why does the cap rot?
Old Mar 4, 2011 | 08:23 AM
Twin_Turbo's Avatar
Electrolysis, iron block, aluminum heads, aluminum radiator & tank and a steel (galvanized) cap. Buy a rad cap w/ sacrificial anode.
Old Mar 4, 2011 | 09:36 PM
AH! Use the newer GM red (Orange?) coolant. That what I use. No rot after that. (Think it goes by the name "Dex-cool".) Not cheap, but after going through the aluminum water pump 3 times in my Jeep with aluminum radiator, I switched to it and like magic, No more corrosion.
Old Apr 2, 2011 | 01:05 PM
BigEd65's Avatar
Car: 1992 Chevy Z28 - Black
Engine: ZZ4 350 HSR w/ 100 shot
Transmission: Automatic - Hurst dual gate
Axle/Gears: Moser 12 bolt 3.42 Eaton gears
Can you post a shortcut I am looking to get a radiator top mount made, I'm running a Be Cool and love the was that one looks
also I just bought and installed this Canton Tank, extremely well made and fits perfectly
Old Apr 16, 2011 | 08:39 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
How did you go about making the baffle for your cap and could you post up detail pics of the piece?
Old Apr 16, 2011 | 04:03 PM
Twin_Turbo's Avatar
see if this works
Attachment 212596
Old Apr 16, 2011 | 04:51 PM
one92rs's Avatar
Car: SOLD!!!!!
nevermind i found my own answer. 173.00 bucks.
Old Apr 16, 2011 | 05:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i actually used a small freeze plug from a chevy sbc kit i had laying around. about 3/4" round? maybe a little smaller. drilled 3 or 4 little holes in it and epoxied it to the bottom of the cap, covering the hole i drilled int he top.
i can get pics if this is not enough.
Old Apr 16, 2011 | 05:05 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
nice tank im buying it
Old Apr 17, 2011 | 03:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you can get them on ebay, 138 and free shipping. best price i have found by far
Old Apr 17, 2011 | 04:47 PM
Twin_Turbo's Avatar
Where? I don't see them on the bay for that price.
Old Apr 17, 2011 | 04:48 PM
Twin_Turbo's Avatar
Oh found them, discount performance parts, good price indeed!!
Old Apr 18, 2011 | 01:27 PM
1BADZ28SD's Avatar
can u post the link for me i cant find it for 138
Old Apr 18, 2011 | 01:42 PM
Twin_Turbo's Avatar
http://cgi.ebay.com/CANTON-RACING-CO...QQcmdZViewItem
Old Apr 18, 2011 | 02:15 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
My cap also rotted.. Plan to paint the cap black and the tank itself silver.. Trying to go for a black..red..silver..brushed color scheme.. This is a nice tank though.. Just needed that 1 hole re-drilled.. I just used the 2 available and all is fine..
Old Apr 18, 2011 | 03:58 PM
1BADZ28SD's Avatar
thank u i look and look and could not find it
Old Apr 19, 2011 | 01:47 AM
If you use the "orange/red" coolant that the newer GM cars are using, you wont have much corrosion. I think it's called "Dex-cool" I started using it in all my cars and there is no more rot. That stuff is designed for aluminum.
Old Apr 19, 2011 | 08:39 AM
  #42
Twin_Turbo's Avatar
Yes, organic coolant will go a long way in reducing/eliminating corrosion. if you ever see an LT1 with the stock coolant you'd notice how clean the internal passages are.
Old Apr 20, 2011 | 01:38 AM
  #43
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Dexcool..yuck.. Anybody I have known that had this in their car always had it clogging and gunk up.. From brand new cars to completely flushed systems..this was added and the coolant system went to the crapper..
Good Ole' Prestone 50/50 is perfect..and if another car you have needs some..guess what..it works with all vehicles..
After you use this in your aluminum radiator..add some Royal Purple Purple Ice or Redline Water Wetter.. Great products and won't harm anything.. Also universal for all cars..
P.S. I am using Prestones full line of Flush..Fill..Protect products..
Old Apr 20, 2011 | 03:44 AM
  #44
I've tried all sorts of things including royal purple, water wetter, prestone, etc. Prestone isnt too popular in AZ as it breaks down and turns white in the high heats. Dex-cool is yucky, though. (Hard to wash off!) But, it does work.
Old Apr 20, 2011 | 10:42 AM
  #45
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I see..
Old Apr 20, 2011 | 10:44 AM
  #46
Twin_Turbo's Avatar
I use the organic coolant in everything I have that is all aluminum including my air tow ater intercooler system. Never had a prob. with it. It's not dex cool brand, simply OAT coolant. Works fine, never a problem.
I think the dex cool turning to mud problem stems from being aerated, low fluid levels, leaks.
Old May 8, 2011 | 05:50 PM
  #47
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
That looks good! I have a question... Was your car originally a TPI car? I notice that you have what looks like a plastic cover around your hood latch. I have a TPI car that I just pulled the motor out of and I'm looking to cover where the snorkels ran.
Old May 8, 2011 | 05:51 PM
  #48
Twin_Turbo's Avatar
Those covers were on all non TPI cars (they never sued the Y shaped air filter housing) so it won't be hard to find one.
Old May 8, 2011 | 06:20 PM
  #49
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
I wasn't aware. Wonder where I can pick this up at.....
Old May 10, 2011 | 07:11 PM
  #50
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I got mine off ebay as well last year, I really like the look over the plastic bottle.
