a/c help please
Old Feb 24, 2011 | 09:48 AM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
a/c help please
not sure how to start taking it out i bought a delete kit for it and i wanted to take the whole thing out please help. does the presure have to be drained out of it or can i just start taking the hoses apart
Old Feb 24, 2011 | 12:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: a/c help please
Unless it's already leaked out, it has freon in the system. Not enough pressure to hurt you or anything.
It's illegal to release the freon into the atmosphere! But, I'm not the freon police, and my head is turned.
Once the freon is gone (through your choice of methods), just a matter of yanking the components out. You'll need the A/C delete pulley to replace the compressor with - unless maybe there's a way to route a shorter belt - BUT you can only remove ONE THING from the serpentine system and reroute the belt - so if you are removing the smog pump as well, then you'll HAVE to get the A/C delete pulley. This is because any other way and you'll be routing the nelt in a manner that will not correctly rotate the water pump in the right direction (since a serpentine car has a reverse flow water pump).
Good Luck!
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
