Fan switch location change questions
Old Apr 3, 2011 | 06:45 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Okay, 87 Camaro, originally carbed 305, single cooling fan. A few years ago I dropped a 1978 350 in it and removed all computer controlled systems. I couldn't get the plug out of the passenger side head to put the fan switch in so I rigged the fan to come on via toggle. Now, I'm dropping a built 327 in and want to do it right this time so I have a few questions.
1. I want the car to run a little cooler so I want a 200 deg. on: 185 deg off fan switch. Can I get a part number?
2. I have an Edelbrock Performer EPS intake, can I move the fan switch up to near the thermostat housing? There are 3 holes near the housing, one will be for heater hose, one for the fan switch, and the other will be plugged. My thoughts is since it's basically just a "ground" plug for the system, it should work, but I just want to be sure.
3. Will the system run properly if I move the fan switch to the intake if I'm running a 180 deg. thermostat?
4. For removing the toggle and implementing the fan switch: Currently, I have a relay: Power - fused line from battery; Switch - toggle; Ground - Body ground; Acc. - fan. Will this work? Power - fused line from battery; Switch - ignition hot wire; Ground - fan switch; Acc. - fan.
Thanks in advance to all that help!!
Old Apr 3, 2011 | 06:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fan switch location change questions
Easiest thing to do is grab a seperate fan controller and install that. Much better than the factory-type switches in the head IMO, easy to wire, most are adjustable - they probe the radiator so you don't have to locate anything on the engine. I'm running a Flex-a-lite controller, it's the best $100 I ever spent!
Old Apr 4, 2011 | 10:45 AM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
I'd like to stick with stock fan switch type. If I can move it to the intake, cool. If I have to keep it in the head, no big deal. I have everything I need to make it work except the actual fan switch as I can't seem to find a part number for a lower temp switch. Every thread I've read on here seems to have bad links for the different temp fan switches.
Old Apr 4, 2011 | 08:46 PM
87350IROC's Avatar
Car: 87' IROC
It will work fine in the intake.
Old Apr 4, 2011 | 09:54 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Thanks! No worries on finding the part number for the fan switch. I got too antsy and bought the hypertech switch that closes at 200 deg and opens at 185.
Old Apr 4, 2011 | 10:54 PM
Car: 1992 RS
Engine: Carbed 350
Good luck - I wasted cash on one of those once as well - it lasted 45 days before it stopped working. At least the autozone crap lasted 60 days. That's why I ultimately went with a seperate fan controller 4 years ago and never looked back. I never have issue with my Flex-a-lite!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
