one fan spins the other don't
Old Apr 3, 2011 | 11:09 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
so my 89 gta with dual fan setup is having problems. when my temp reaches 220 and my fans kick on the driver side does not spin and the passanger side is working. anyone know what i should look for? is this common?
Old Apr 3, 2011 | 11:38 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: one fan spins the other don't
Test the one that won't spin by hot wiring it. If it doesn't spin even then? The motor is out. Cheep fix. Buy a new fan motor at Autozon/Carquest/NAPA/which ever you shop.
Old Apr 3, 2011 | 11:42 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
isnt one fan for the AC when its on and one for when the car gets hot?
Old Apr 3, 2011 | 11:44 PM
Car: GTA
Sorta.
One is for the AC, regardless of engine temp. But IIRC, both can be turned on by the ECM, regardless of AC or not.
Old Apr 3, 2011 | 11:57 PM
Car: 1990 camaro RS
Engine: 305 TBI
ahh ok i only have a single fan on my RS so i wasnt sure, but i figured id throw it out there
Old Apr 4, 2011 | 12:06 AM
Car: 91 formula
how should i go about hotwiring? can you please explain. thanks.
Old Apr 4, 2011 | 02:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Normally the driver side goes on first, connected to power by the computer. The other one is either operated by the fan switch or the AC. Maybe the plugs are switched? What happens while the car is running when you turn on the AC?
Old Apr 4, 2011 | 05:33 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
To check fan, remove the connecting plug and note which side has the solid black wire going to it and which has the black with red or pink stripe going to it. Hook the pin the black one went to to ground and the other to 12 volts like off the battery with a jumper wire. Now it either works or not, but try turning on the AC first
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
TA8487
Aug 16, 2015 12:21 PM
