View Poll Results: 20
cooling
100.00%
need help
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
tryed every thing need help cooling my babie
Old Apr 22, 2011 | 09:21 AM
86 irock z28's Avatar
Car: 86 irock z28
Engine: 305tpi gt 350 though then ls
Axle/Gears: lol no clue new to cars
ok like i bout a 86 i rock z28 it was orgenly at but i switched it over to a 5 speed so it still has a brand new at radatior in it i have also replaced the whater pump thermast it has a after marckt fan on thier that pulls more btu then the oled singol one it is acktavated bye a switch i wird in to my dash i hade a thermasta sincer that whent in to the radatior but becas of the over heating i put it in thier so i can turn it on as sone as i start the car it a 91 air duck on it culed that be the isues newer parts better tecnolge butter parts right ? at least thats what i was thinking lol it draws the air strate in frome the 2 holes in the frunt i have to run it with out fog lights beacase it gets to little aire flowe ok kool i can deal with that but if it hot out i have to run the heat and fan constently and the mug still over heats i noticed that the ac condicer in frunt of the raditor is smashed up some culed it realy cass that much restictive flowe and if so whear can i get a good cheap one ??? pleas help
Old Apr 22, 2011 | 01:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: tryed every thing need help cooling my babie
OK - I'm having a really hard time reading everything because your not using punctuation, not making complete sentences, have very stray thoughts, and you need a spell checker really really bad. But ... from what I'm picking up ...
1) Your A/C condensor (the radiator-looking thing in front of the actual radiator) has many mashed fins, right? This would definitely restrict the air flow - tremendously. If you plan on keeping A/C, then you need to replace it, or at least get in there with a pick or screwdriver and straighten all the fins back out - very hard work and very tedious to do. If not using or keeping the A/C, just remove the condensor.
Also note - the small space between the condensor and the radiator is notorious in our cars for collecting alot of trash (leaves, twigs, road trash, etc) - clean all that out as well.
2) You DO or DO NOT have the air dam in place? The air dam should be a plastic piece, about 3 ft long and about 4 inches tall, that is mounted directly under the radiator.
3) What temp thermostat are you running? Factory spec is a 195, but do not go lower than a 180 - anything lower is just too low - it will freak out the computer, making your car run rich all the time because the engine is too cool. Even a non-computer controlled carbed car should never need lower than a 180 stat.
4) Cooling fan - as I read, you have your fan rigged to a switch inside car, and you turn it on/off manually, correct? If so, this is a disaster waiting to happen - some day you'll forget, or in an emergency someone else will drive your car and not know, or something. I'd look into an aftermarket fan controller - they get temp readings from a probe that goes between the radiator fins, and they work really well. I run an expensive Flex-a-lite model ($90), it has alot of nice features including adjustable temp range, and performs flawlessly - but cheaper models with less features are available.
5) Are we assuming the temps are hot because of what the stock factory temp gauge reads? These gauges on a good day are far from accurate - unless the car is actually bubbling over into the oveflow tank, and making steam - you are not overheating. From the factory, these cars were designed to run hot to help with emissions - stock factory fan setups the fan came on at 220, and it's not uncommon at all to see a 3rd gen car run 240 or even higher in the summer without it actually overheating (since the factory gauges suck). You might try a new gauge sender to see if it makes the gauge read differently (it's between #1 and #3 spark plug, in the driver side head - has one single green wire to it).
Old Apr 22, 2011 | 07:55 PM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
The single biggest thing I did to reduce my engine temp was an aluminum radiator. Picked it up off ebay for less than $100.
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Out-Cast
Aug 17, 2015 10:57 AM
sreZ28
Aug 14, 2015 07:48 PM
Sherpajames
Aug 7, 2015 06:56 PM
