AC Refresh Needed
Old Apr 27, 2011 | 10:00 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
AC Refresh Needed
About 3 years ago I had the AC rebuilt. Replaced the compressor, accumulator, orfice, and charged it with Freeze 12. It worked good but last year when I started to drive it during the summer(stayed garaged through winter) I turned on the AC and it was cycling. Topped it off with a can of freeze 12 and it was good again. Samething this year, it was garaged all winter and I just started driving it again and the Compresssor cylces every 2 seconds. Should I just fill it back up with freeze 12 or what?
Old Apr 27, 2011 | 10:48 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: AC Refresh Needed
Sounds like you have a leak somewhere. I would charge it back up and put some dye in the system. Run it for a while and look to see if you can find the dye leaking out somewhere. Could be something as simple as an o-ring.
Old Apr 28, 2011 | 04:35 AM
Axle/Gears: Stock
Will i be able to see it w/o the light?
Old Apr 29, 2011 | 12:08 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
You can buy leak dye with special (yellow) glasses that make finding the leak easier.
Old Apr 29, 2011 | 06:56 PM
Axle/Gears: Stock
You think this little guy pictured is where the leak is? Or is it clutch dust?
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
