Is this time to replace?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Is this time to replace?
which one?? the unplugged sensor is your temp sender, the other is the temp sensor, the rusty thing is your thermostat neck
Thanks for answering all three questions that have been bugging me for awhile. I didn't even know that it was unplugged. How do I fix figure out and fix this mess? Especially the coolant leaking problem?
Last edited by -LateNite89-; May 14, 2011 at 09:34 PM. Reason: Forgot to add something.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Thermostat housing is leaking replace the gasket and thermostat while you are in there...
Engine: L31 350
go to autozone and get a new thermostat, thermostat gasket and neck since your looks like its about had it. the unplugged sensor is for your gauge readings
Engine: L31 350
to fix the problem, drain your coolent into a bucket, take off the radator hose, take the two bolts out of the rusty thing and it will come up, inside youll see the thermostat. pull that out and take it to autozone so you can get the right one and get a new gasket aswell. then just reassemble, just remember to take a razor blade and scrap off the old gasket on the neck if you dont replace it and off the block!!
When I bought the car back in August it was like this. Makes me nervous to know that I've been driving around in this condition. This helped out a lot since I knew nothing about this and the Haynes Manual didn't answer my questions. Thanks guys.
Engine: L31 350
its gotta be around there, normally attached to the wires that go to the AC compressor, look at the lomb and you should see a green wire sticking out some where not far from there.
Engine: L31 350
your neck looks fine now that i looked again, just get a new thermostat and gasket. its all under $10 at autozone. just remembed to get the old gasket off and to drain your system before you do this!! put it in a container that you can use to put it back into the radaitor
Engine: L31 350
might be different on the v8s but i doubt it, might just be tucked away or in the lomb. does your gauge work?
Engine: L31 350
sounds like a preview owner installed a new one in one of the other holes. and just kept that sensor there to plug it.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That's a much earlier model neck that somebody put on that had different fittings there that your year model doesn't need. Stock one for you is aluminum. That old cast iron one is harder to seal well. You might consider replacing it with one probably easily found at the JY. If you do that, sand down the sealing surface on something flat to fix any slight warpage that may have occured and get a new gasket and you should be good
Your temp gauge sender is on the driver side of the head toward the front
Update: Went to the yards today to look for a newer thermostat neck (see pic above), and the fbodies near my area were pretty much stripped. Does anyone know which store could help? So far Autozone and Pep Boys have turned up... Nothing. Zip.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got an extra one around somewhere I can let you have for like $15. Sealing surface already flat. Get me your email address for pics or other info, Henry
Includes bolts as well
The stock water outlet is cast chinesium. Total crap.
The one you have is a replacement one, made of cast iron. FAR FAR better than a stock one. Don't replace it, just clean it up and put a new thermostat & gasket on it. Even at that, a brand-new one at the parts store (remember, the official word is "water outlet") is only about $12.
Be prepared for the bolts to be REAL hard to get out, with them being constantly saturated in water like that. Expect them to be corroded in there pretty solid. If one breaks, DON'T try an Ez-Out, those NEVER work, it will break off as well and then you'll have a real mess on your hands. Instead, grind or file the broke-off bolt fragment flat; center-punch it in the exact center with a good, sharp center punch; and drill it out with progressively larger bits, like a 3/32", then a 3/16", then a 5/16". You may be able to remove the remains of it by hand once you get that far. If not, use a Heli-Coil to repair it. Resist the temptation to drill it out really huge and use a larger bolt; that will eventually come back to bite you in the butt. Just do it right.
Sooo I ended up going to Oreilly's auto parts and ended up getting these items. I didn't check the updates messages until tonight. It's not made out of cast iron, but I don't know. Anyways, take a look. Should this be okay? Or just take it back?
NBrehm
Aug 25, 2015 11:49 PM
