a/c stupidity.
Old May 21, 2011 | 04:51 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
a/c stupidity.
with all due humility, heres what happened.
i have been collecting parts for a year or so, to do both my wifes and mine verts. I did hers first with no issues. cools extremely well. im still in the process of tweaking that one (with the much app'd help of reid flemming).
today i did mine, it flew together. even so well that i was chatting on the phone while putting the orifice tube in its hole.
all together,vac'd down. put in 2 cans. started the car to top off the rest of the way, it took the third. then i put the guages on.....wow the low side red lined, andthe high was 500. WTF. no cold air everythings getting hot, not cold.
time to walk away for a moment. i figure there has to be a blockage of some type.
i blew everything out before i assembled it. i check the evap first. maybe a bad orifice tube.
its pushed all the way down. ----BINGO. While chatting about how well the build was going, i put the o-tube in upside down.
i vac'd it back dwn and refilled.. eveything is well now. hope this helps somebody from making the same mistake.
Old May 21, 2011 | 05:59 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: a/c stupidity.
thats the way we all learn . at my age i'm still learning that same way . (BTW i'm a 16th degree on my belts) good luck , cheers .
Old May 21, 2011 | 09:07 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: a/c stupidity.
at least ya figured it out!
Old May 21, 2011 | 10:07 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: a/c stupidity.
I was gonna say it sounds like the orifice got locked or else put in backwards.....I know you're not the first person to have done that. Those orifice tubes DO look like they should go in the other way.
Old May 21, 2011 | 11:22 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: a/c stupidity.
yup I think im going to vacuum my a/c and change my orifice this coming up week for maintenance
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
