Fan motor relay
Old May 25, 2011 | 01:51 PM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Fan motor relay
I did a search but didn't find what I needed. Can someone with a dual fan L98 car post pics of where exactly the fan relay is? There are a ton of "relay looking" boxes on the car.
Old May 25, 2011 | 02:29 PM
Zaar's Avatar
Car: 1988 Iroc-Z tpi 5.7
Engine: ls2
Transmission: 4l80e
Axle/Gears: 3:42
Re: Fan motor relay
right on the side of the engine bay next to the battery
two oval top relays they are prone for burning out check the wiring also dont be surprised if you need to replace the wiring...
Old May 25, 2011 | 06:41 PM
Transmetal's Avatar
Re: Fan motor relay
Ok, on the passenger side next to the charcoal canister I found the relay. Are u saying there are two of them?
Old May 25, 2011 | 06:45 PM
Zaar's Avatar
Engine: ls2
Transmission: 4l80e
Axle/Gears: 3:42
Re: Fan motor relay
Forgot that you have a bird. Yeah that's where there are two relays side by side one is your fan relay. If I am correct is there two there next to your canister? But yeah there ya go
That's the relay
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Bert87
Aug 23, 2015 03:50 PM
Leggman1
Aug 6, 2015 04:15 AM
