Cooling Switch Issues
Old Jun 8, 2011 | 12:00 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I'm having the typical cooling problems with my single fan 89 IROC-Z. I have replaced the water pump, radiator, thermostat, the cooling fan relay on the firewall and the cooling fan switch on the passenger side head. My switch wiring connector crumbled when I reattached it and now the fan doesn't even come on when I turn on the A/C. I can drive it as long as I stay out of stop and go traffic. I've had no luck trying to find a new connector. Does anyone know where I can find one? I may buy the Hypertech unit as it has the connector and comes on at a lower temp. Any suggestions?
Old Jun 8, 2011 | 04:16 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Cooling Switch Issues
if the autoparts doesnt have one then your best bet is going to be a junk yard. possibly from some place online.
Old Jun 8, 2011 | 06:57 PM
Richboll's Avatar
Engine: 305 TBI
Thanks, I'll try to hit a junkyard this weekend. I was hoping to buy a new connector but after searching the internet I haven't been able to find one.
Old Jun 8, 2011 | 07:42 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Camaronewbie always posts a Dorman part # for this connector when this question comes up. Should be readily available at your basic parts store or at least they could get you one. Think it's the same as a knock sensor connector. I'll try and search around to see if I can find the part #
Found it check out post#5 on this thread
https://www.thirdgen.org/forums/cool...oling-fan.html
But on here now it's part#85102 on page 30
Old Jun 8, 2011 | 08:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
See what I get for working late - had my answer stolen! Ha ha!
Until you can get the part - simply ground the wire from the dead connector anywhere metal - this will make the fan run always with key on - at least it'll keep you cool until you get it fixed.
Old Jun 9, 2011 | 12:23 AM
Richboll's Avatar
Engine: 305 TBI
Thanks guys..The info is exactly what I was looking for. I've ordered one of these (Dorman 85140) from www.rockauto.com for $10.82 (includes shipping) and hopefully be able to go on to the next issue...cruise control not working. And this thing only has 59K miles on it.
Thanks again for the help!
Street Lethal
Apr 30, 2019 12:14 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
TheExaminer
Aug 26, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
Leggman1
Aug 6, 2015 04:15 AM
