92 over heating
Old Jun 9, 2011 | 10:19 PM
ty001's Avatar
Car: 91 Camaro
Engine: 3.1
92 over heating
Ok here is the low down. I have a 92 camaro with a 305. Ive had to replace the thermostat and the guy who had it before me cut the temp switch and wired it to a switch under the dash. Now when I drive the car I have no problem with the temp at all, but do to other reasons, my little sisters has had to drive the car. When she shes always saying its over heating. When the car is driven the fan is always turned on, allowing the car to run around 160. She gets in an it runs fine till she kicks the air on then she says with in maybe 10 minutes or so the gauge has moved into the red and its over heading. Now I know its not leaking and it is resurrecting, but we cant seem to figure out the problem, because it only happens when she drives it. Any ideas?
Old Jun 9, 2011 | 10:22 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: 92 over heating
where you at in indiana?
Old Jun 9, 2011 | 10:37 PM
ty001's Avatar
Car: 91 Camaro
Engine: 3.1
Re: 92 over heating
South central part. About 45 from kentucy.
Old Jun 9, 2011 | 10:45 PM
Engine: L31 350
Re: 92 over heating
ah
Old Jun 10, 2011 | 07:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 over heating
The most absolute best favor you can do yourself is to get a sperate fan controller, and wire it in. They are easy to do, come with preset on/off temps or adjustable (depending on how much you spend). I run a Flex-a-lite, cost $100, but worth every penny - it's been 100% dead on for last 4 years. But cheaper models with less bells/whistles are available for as little as about $40.
Old Jun 10, 2011 | 11:12 PM
RyanEricW's Avatar
Re: 92 over heating
My car does the same thing...perfectly fine til I turn on the A/C, and wait about 10 minutes.
305tbi, recently flushed coolant...to no avail.
I'm wondering if it has to do with poor wind incoming on the front of my camaro through the grill.
Old Jun 11, 2011 | 01:06 PM
Engine: L31 350
Re: 92 over heating
the grille provides NO airflow...
Old Jun 11, 2011 | 05:29 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 92 over heating
Is your airdam on the car?
Old Jun 11, 2011 | 05:56 PM
RyanEricW's Avatar
Re: 92 over heating
Really? Because it leads directly at the radiator on the passenger and driver side, while the center is solid, for a license plate mount.
And yes, the airdam is in good shape, fully mounted stock part. I wish I could get rid of that damn thing, it scrapes all the time.
Old Jun 11, 2011 | 06:17 PM
Engine: L31 350
Re: 92 over heating
yes really, that statment you posted has been said before many many times!! and proven again and again that it has no flow. search it and see what you come up with.
Old Jun 11, 2011 | 07:37 PM
RyanEricW's Avatar
Re: 92 over heating
Proven by who? If you are going to debunk my statement, show some proof, don't arbitrarily tell me there is "proof" and I need to find it. What kind of argument is that? Let's act as if we are educated here and provide some credibility as well.
Air passes across the condenser at the VERY least, with air passing through the radiator, it removes heat through the latent heat of convection.
Old Jun 14, 2011 | 02:27 AM
RyanEricW's Avatar
Re: 92 over heating
I was interested in a response, if there is proof please let me know as it will affect my future plans for my car.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
