Car run too hot uphill only!
Old Jun 12, 2011 | 02:43 PM
ebd85ta's Avatar
85 TA 305 TPI, has a Hayden fan kit set to kick on at 210. Runs between 190-220 at all times and any weather EXCEPT going uphill for any extended time. Creeps over 230 and is heading up so Ive always just turned around back downhill, and it immediately drops back down. Weird. Any ideas? Water pump is fairly new as well.
Old Jun 13, 2011 | 01:54 AM
BK5Murray's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Transmission: 700r4 auto
Axle/Gears: 3.73 posi
Re: Car run too hot uphill only!
This is a long shot, but you MIGHT have an air pocket that lodges itself in the back of your motor when you go up hill. I would say to jack up the rear end, take off your radiator cap, start it, and let it warm up. If the coolant level goes down, top it off.
(jacking up the rear end would cause the air pocket to shift to the front and escape)
I think it would be worth a try.
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
86Base
Aug 8, 2015 01:34 PM
