overheating built 305
Old May 27, 2011 | 04:09 PM
toswald84's Avatar
Car: 84 Z28
Engine: Carbed 305
ok i have a .030 over 305 10:1 compression iron heads... it runs at 215 just cruisin around and 245 in traffic.. new water pump, electic fan on a switch on all the time, 160 thermastat, and new radiator, and i have the air dam on.. also with the cap off if i start it, it will puke out the rad, im running straight water also ... im thinking headgasket... any other ideas??
Old May 27, 2011 | 04:12 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: overheating built 305
run coolant not straight water
Old May 27, 2011 | 04:23 PM
Awesome-X's Avatar
Car: 87 Camaro
What difference do you think that would make, exactly?
Old May 27, 2011 | 05:08 PM
Badcompany784's Avatar
Car: 92 25th anniversary
Engine: TPI 305
Axle/Gears: NA
over time water boils off and the anty freeze is a cooling and lubricating agent
Engine: TPI 305
Axle/Gears: NA
try running a bigger fan
Old May 27, 2011 | 05:57 PM
Awesome-X's Avatar
Car: 87 Camaro
It shouldn't be reaching a temperature that would allow it to boil in the first place, although I will admit antifreeze is a lubricating agent that you should have for the health of your water pump, I will also say that it should make no difference in this situation.
Old May 27, 2011 | 05:59 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
antifreeze has a lower freezing emp and higher boiling temp, so when your engine gets hot the water boils off, because operating temp is higher than waters boiling point, thats why antifreeze is used
Old Jun 11, 2011 | 08:46 PM
Toqwik's Avatar
Check timing.
Old Jun 13, 2011 | 02:04 AM
BK5Murray's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Transmission: 700r4 auto
Axle/Gears: 3.73 posi
Make sure your fan is blowing the right direction. The first time I pulled my rad and fan, I plugged it in wrong and it ran backwards. Just a thought.
mhatfield 14
Oct 24, 2015 07:48 AM
LittleFranks
Sep 17, 2015 12:22 PM
mustangman65_79
Sep 1, 2015 03:51 PM
theurge
Aug 21, 2015 12:46 PM
