air filter choking sound
Old Jun 15, 2011 | 08:34 PM
joeyspagz's Avatar
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
when i chop my throttle the air filter makes a loud squeak noise like its choking, and theres a small bog help!
Old Jun 15, 2011 | 10:48 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: air filter choking sound
a squeak or a whistle?
Old Jun 16, 2011 | 12:59 AM
BK5Murray's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Transmission: 700r4 auto
Axle/Gears: 3.73 posi
With you having the TPI, it could be a mass air flow sensor issue or your filter could be dirty. Do you have a high flow filter, like K&N, Spectre, etc?
Also, there have been tests done that prove that if you use a high flow air filter on a vehicle with a MAF sensor, you will get worse gas milage and run richer. I believe that is mostly on Dodges though. Just thought of mention it though. Just in case.
Old Jun 16, 2011 | 10:10 AM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
im not sure if its a k&n because it doent say it but its the red k&n color with chrome trim
Old Jun 16, 2011 | 01:57 PM
BK5Murray's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
It just happens when you rev it up real quick though? What does the motor sound like if you hold the rev at 2000 rpm or so? Does it have a miss? Act like it's starving for something? And is your throttle response good or does it have a delay?
Old Jun 16, 2011 | 03:49 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
there is a delay in throttle response and its not missing. it does sound like the filter is not letting enough air
Old Jun 16, 2011 | 10:28 PM
BK5Murray's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Take apart your air intake tubes and see if you have anything in there. Dust, leaves,anything that would get in the way. Or try cleaning and oiling your filter. The high flow filters are cotton and need to be oiled every once in a while to do their job.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
