what is a good water pump for an 85 T/A?
Hi,
Going to be putting in a new cam, intake, and timing chain on my 350 in my 85 T/A. What water pump should I use? And, is there a preference on timing chain sets?
Thanks!
Thanks!
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: what is a good water pump for an 85 T/A?
A new water pump would be good. An AC Delco if you want an original type. They sell aftermarket aluminum ones which are lighter and look better but that's all your decision. Timing chain wise a roller chain would be best. A single roller has bigger rollers on it and will work fine, or you can run a good doube roller but either or is fine. Just get a high quality piece from Cloyes, Comp Cams, etc. and you'll be okay. Good luck
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I've installed the Cloyes double roller in many small block Chevys and they have worked very well and seem to hold up over time. Probably the only more reliable cam drive is a gear drive and I hate the whining. Belt drives are okay for racing but not reliable on the street.
I installed my Edelbrock Victor waterpump 12 years ago. It's a high flow unit that flows 25% over the stock pump, plus it's lightweight aluminum. I am very happy with it.
Thanks for the helpful advice guys!
Would I want the 'long' or 'short' water pump?
And, do I have to drop the oil pan to do the timing cover or is there a way around that fiascle? ;-)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Long pump, standard rotation if you have V belts, reverse rotation if you have serpentine.
You have to at least drop the front of the oil pan to do the timing cover.
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah you dont have to drop the whole oil pan you can drop the front a little, basically by removing the front bolts, and kind of prying it in and out. use the rubber and some RTV black silicone, then you kind of slide it back in and bolt her up.
THanks a bunch!
There seems to be alot of Cloyes timing chain sets. Is there one in particular I should be looking at for this 350?
Are the Lunati chain sets good? Putting in a Lunati bracket master II (#00017) cam I think.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
