1984 Z28 Small Block 400
Old Jun 19, 2011 | 02:58 PM
RobertB's Avatar
I just bought a 1984 Z28 W/ SB400. Should I upgrade fan or radiator? I heard they have cooling problems.
Old Jun 19, 2011 | 03:04 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: 1984 Z28 Small Block 400
the 400s have a problem when ppl put other SBC heads on them and forget to dril out the steam holes since the 400 has simiesd bores they need to have the steam hole drilled out, if thats good there shouldnt be a problem the cars themselves run warm but if the fans working like it suposed to you should be fine
Old Jun 19, 2011 | 03:14 PM
RobertB's Avatar
Good to know. Thanks. The guy also threw in the origional 305 with the heads on it. How do I tell if the heads on the 400 are for that block? Is it stamped on the front?
Old Jun 19, 2011 | 03:16 PM
Car: 1990 camaro RS
Engine: 305 TBI
you can check the casting numbers, youd hafta pull a valve cover off to check that, altho they could be any SBC head and theyll work as long as the vent was drilled out. imo drive it and watch the temp, if it doesnt overheat dont worry about it
Old Jun 19, 2011 | 03:17 PM
RobertB's Avatar
Thanks again
Old Jun 19, 2011 | 04:54 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
my 400 ,im using stock radiator (new) from 305 car and using dual electric fans from and iroc,temps about 190-210 on a hot day
Old Jun 20, 2011 | 01:22 PM
RobertB's Avatar
I think that's good to go with to be safe. The fan was and is out of the car when I bought it so, half of the work is already done.
jhawkeye
May 25, 2022 06:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Exxon Limited
Aug 9, 2015 08:13 PM
