Coolant Leaking from rear on engine? Help me ?
Old Jun 28, 2011 | 02:23 PM
Dimebag333's Avatar
The other day i had a cat back system installed on my 1990 iroc-z. when i got home my wife and family wanted to hear it so i rev'd it up 3 times and it started pissing coolant all over the ground? I can see that its coming from somewere in the back of the motor? after letting it cool down over night i went out side check the fluid lvls only one that was bad was coolant. so i topped it off started car no leak. drove it to school no leak when i parked. soon as i got home parked it same thing started leaking. and its not just a drip it took half a bottle of coolant to top off both times. plz help me guys point me in the right direction to fixxing this i dont want to see my iroc-z DIE!! ty guys
Old Jun 28, 2011 | 03:06 PM
turbinator3's Avatar
Re: Coolant Leaking from rear on engine? Help me ?
out of the engine? or a heater hose leaking maybe?
Old Jun 28, 2011 | 04:42 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
To me it sounds like the heater core is leaking and the drain hose is dumping coolant out. Maybe the leak isn't bad when the heater core bypass valve is shut and then it opens when the car is shut off. I'd check it first anyway.
Old Jun 28, 2011 | 07:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
get a flashlight , open hood , look for leak . best advice we/i can give with out more details . if it's from pass. side a common place for leaks is hose going to manifold near dist. . not a slam , but look and give more info. . good luck .
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
