87 5.7 iroc z runs hot, help please?!
Old Jul 3, 2011 | 02:24 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Engine: 383 Mini ram
Axle/Gears: borg warner 9 bolt
I have an 87 iroc z with the l98 350 engine in it.
Its been getting up past 210, and while driving conservatively it runs between 220-230 deg.
Ive replaced the thermostat with a 160 deg, replaced the water pump, and radiator cap.
The fan is wired to stay constant.
IT doesnt have an air dam, but im not so sure that could be causing all of this.
Is this something to worry about? i dont know whats actually considered "overheating"
Any help/ideas would be much appreciated!
Old Jul 3, 2011 | 06:22 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 87 5.7 iroc z runs hot, help please?!
Gotta have the air dam and baffle or you will have a bunch of cooling problems. Id put a 180 stat in there too.
Old Jul 3, 2011 | 08:58 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
+1 the 160 is way to cold and the air dam is a must.
Old Jul 3, 2011 | 09:30 PM
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
I had the same issue and trust me its the AIRDAM I dint believe that a little piece of plastic wold work better than an aluminum radiator and 3000 cfm fan
Frozer!!!
Jan 19, 2024 04:55 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
