Installing a stock radiator and fans
Old Jul 16, 2011 | 03:51 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I just did an engine swap and im now reinstalling everything. Im getting alittle frustrated with installing the radiator and fans. Does anyone have pics they can post of where the rubber hold down pieces go and how everything is mounted and secured in?
Old Jul 18, 2011 | 03:56 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Installing a stock radiator and fans
i dont have any photos, but their placement should be pretty straightforward. the upper plastic cover has indentations for one on each end and so does the lower frame section. the rubber pieces should cup over the seam where the end tanks and core come together. there is no additional hardware for these pieces because they are held in place thanks to the upper plastic cover pushing down on the radiator
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
bryan623
Aug 10, 2015 11:33 AM
Leggman1
Aug 6, 2015 04:15 AM
