Temp Gauge is stuck
Old Aug 4, 2011 | 03:23 PM
Lippard9202's Avatar
Car: 1986 Iroc
Transmission: 7004r :(
Temp Gauge is stuck
as the title says my temp gauge ( along with the tach) are stuck. the temp is pointing straight down, and the tack reads redline even when off, when I parked today the fluid in the overflow was bubbling, and I had no way to know what temp Im at. so I thought i might as well get a new thermostat, its been a few years... any ideas on the gauges would be helpful, sorry for the rant. I did look for info on it, but i couldnt find anything, and I have to leave in like 5 mins, so sorry if I missed a similar thread THANKS!
Old Aug 4, 2011 | 05:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Temp Gauge is stuck
temp guage sender (assuming a V8) is on driver side, in the head, between #1 and #3 spark plugs. It will have a single ngreen wire to it, with a female spade connector on the wire - should stay as green wire all the way to the dash.
Your temp guage issue is either 1) the temp sender, 2) the green wire, or 3) the guage itself.
Old Aug 4, 2011 | 05:55 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
The bubbling In your overflow is most likely from a bad radiator cap. Had this happen in my car.
this thread may help some:
https://www.thirdgen.org/forums/elec...mperature.html
Old Aug 4, 2011 | 10:00 PM
Car: 1986 Iroc
ahh, very helpful, thanks! Ill check that out tomorrow
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
