Water outlet housing
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The Water outlet housing.
So I have searched and searched for a housing with a solid top.( with out the sensor holes).I have the GM part #10045204 off of the piece I have now that is pitted and warped to a small degree and was leaking. The man at Napa Auto says that they are universal now and you just plug the holes. That sounds lame. I looked at those and the opening is even facing the wrong way. I have ran every part # I could find on our site but nothing matches up. Would someone please help me out and give me a part # and were to buy it. My car is out of commission until it is fixed.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Water outlet housing
If you just need a stock TBI one in good shape I've got a couple of good spares. Get me your email address for pics or other info, Henry
a water outlet thermostat housing for a 1969 camaro works great. and i am still using it on a tbi engine as well with a factory gm tbi manifold.
Car: 1989 Pontiac Firebird
Engine: 305 Tbi w/lt4 hot cam
Axle/Gears: torsen 3.42
Years ago I dropped my original one and it cracked.. the part store ones are iron and rust instantly.. I used to call it "the wart" cause it was ugly on the manifold with pipe plugs sticking out..
try this one, its GM and aluminum, looks much better...
http://www.summitracing.com/parts/NAL-10108470/
its the one that came factory on tbi and comes with the serpentine belt kit.
Engine: TBI,5.0
