Any one know of a good fan
Old Aug 13, 2011 | 10:07 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
I am wanting to upgrade my stock fan for something that will keep my 383 cooler. I want something that is a direct replacement and can use my stock wiring. Anyone have any suggestions
Old Aug 14, 2011 | 10:14 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Any one know of a good fan
I have looked and they don't make a direct replacement unless it is stock. A 12 inch fan fits the best and of course CFM and amps is what you look for. I installed a 12 inch pusher fan in front of the condensor to help at an idle. I also installed a 5.5 inch pusher fan on the trans cooler for a total of four fans. I also just made an aluminum air dam that bolts under the rad support to replace the factory plastic one and that seems to help more than anything. The more air the cooler it will run.
Old Aug 14, 2011 | 03:28 PM
Engine: 383 stroker
thats cool. Im sure there has to be a commonly used fan setup for our cars out there somewhere
Old Aug 14, 2011 | 04:22 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
been reading about the ford taurus mod
Old Aug 14, 2011 | 07:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
ANY fan can use the stock "wiring" - they just won't have the same plug to connect to. Stock wiring uses a relay - bottom line is the relay supplies the 12v+ and the fan is grounded anywhere you like. So, any fan that fits in the space will work - just won't attach with the stock upper/lower fan mount - but you can leave the top "mount" in place, and use rad fan zip-ties to attach fan directly to radiator (better anyway to have fan right up against radiator where air can't get sucked 'around' the radiator - you want the air to get sucked through the radiator).
But, in my personal opinion, the factory fan wiring (ie the thermo switch in the head and ECM programming) is the main issue - they are set for such high temps from factory (to help reduce emmissions) that by the time the fans come on, it's too late to do much cooling. I always recommend an adjustable seperate fan controller where you can change the temps and adjust the cooling effect to satisfy YOUR engine rather than satisfying the EPA and their emissions requirements that GM could only meet by making the cars run too hot.
Old Aug 14, 2011 | 10:50 PM
Engine: 383 stroker
well when I put my 383 in I went to carb and in doing so eliminated the ecm so my fan is currently set up to run whenever the key is turned on.
Old Aug 14, 2011 | 10:52 PM
Engine: 383 stroker
No I havent heard of it
Old Aug 15, 2011 | 08:51 PM
Car: 1992 RS
Engine: Carbed 350
Then I'd definitely invest in a seperate adjustable fan controller. I run a Flex-a-lite, and although pricey at $100, it's been worth every penny for the last 5+ years.
Ford Taurus "mod" is just using a Ford Taurus fan - they were a good size and flowed alot of air, and since one can be snagged at a local JY for cheap, alot of folks like them.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
TA8487
Aug 16, 2015 12:21 PM
