Fan stealing too much power?
Old Aug 16, 2011 | 11:14 PM
ChrisLeBlanc's Avatar
Car: 1986 Firebird
Engine: Swapped 1986 Trans Am 5.0L TPI
Transmission: Gearstar Built Level 2 700r4
Axle/Gears: 3.42 Peg leg / Soon 2.77 BW
I have an 86 Firebird with a 305TPI swapped in with a Hayden adjustable fan controller. Whenever the fan kicks on the motor tries to die. I used the junction box from the 2.8 harness to supply "Hot" wires to the alternator, Fuel pump, and fan controller. Could the fan be robbing the fuel pump of power or overworking the alternator? Let me know your thoughts. Thanks.
Old Aug 16, 2011 | 11:26 PM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: Fan stealing too much power?
i have the same problem,when i flip my fan switch.lights dim idle drops a lil,then pick back up,and all is fine.its because the alt cant handle the sudden voltage,so maybe need bugger alt,or re grounding engine to batt,engine to firewall,alt to batt
Old Aug 18, 2011 | 03:06 PM
Car: 1986 Firebird
I seem to have solved my own problem, try tightening the alternator belt, fixed my problem. For now at least. Lol.
Chuck84TA
Jul 15, 2016 09:05 PM
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
sailtexas186548
Aug 24, 2015 10:11 PM
