cooling issue running 240 to 250 constant
Old Aug 18, 2011 | 10:26 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
just check whats my trouble code and it is trouble code 12 and 51 ? i have 89 camaro rs 5.0 tbi with k&n air filter and 2.5 in exhuast with flowmaster last owner had removed the cataylitic converter car runs fine idle is around 2500 i belive i drove 100 plus miles the other day only isssue is it runs 250 for coolant temp i just got 160 thermastat new coolant temp sensor and about to flush fluid with water then put in 50/50 mix as got airdam and chin spolier off 90 camaro i know its either the prom or ecu but not sure where to start to troubleshoot
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: cooling issue running 240 to 250 constant
thanks /
Old Aug 18, 2011 | 11:45 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Originally Posted by zachary3
thanks /
IDLER at 2500RPM's??????
Old Aug 18, 2011 | 12:09 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
If idle is around 2500 that's way way to high. Are fans kicking in properly? If they are not it could be a blown relay or a bad temp switch.
Old Aug 18, 2011 | 02:13 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea fans kick in around 250 or so
Old Aug 18, 2011 | 04:11 PM
Engine: 383 SBC
That sounds way to high. Either your gauge is wrong or you have issues with the sender/switch.
jklein337
Sep 19, 2018 06:23 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
1nastygta
Aug 8, 2015 07:38 PM
Leggman1
Aug 6, 2015 04:15 AM
