Evil accumulator will not come off!
Old Aug 18, 2011 | 01:41 PM
92'maro'vert's Avatar
I am attempting change my a/c system over to R134a as the old R12 compressor died. I am replacing all the parts I can as my 92 v6 vert is pushing 20 years old, and I am in Phx and a/c is a must. I can not get the rear fitting/nut to loosen on the accumulator! The tube going back into the firewall wants to bend and I do not want that to break! Is it by chance reverse threaded?
Also, can anyone tell me what the factory # of lbs of r12 went into this system? I know I can only use 85% of R134a, but my label melted off of the old comp.
I appreciate your help!
Old Aug 18, 2011 | 02:57 PM
Re: Evil accumulator will not come off!
Use a 2nd wrench to support its hex.
Old Aug 18, 2011 | 03:10 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Should be 40OZ of 134, if memory serves (ims)
Old Aug 18, 2011 | 03:26 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Use penetraing (PB Blaster) and some heat it'll crack loose....
Old Aug 29, 2011 | 07:04 PM
Thanks to all! I finally got it off after calming down and of course wd40 and bigger adj wrenches!
b4ccamaro
Jun 5, 2016 01:48 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Nick McCardle
Sep 10, 2015 08:36 PM
