fans not right
Old Aug 27, 2011 | 06:53 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
fans not right
hi my primary fan i think its the primary turns on as soon as you start the car and the secondary never turns on at all what would cause the primary to run all the time? i have changed the two coolant temp sensors the on in the intake and the one in the driver side of the head
Old Aug 27, 2011 | 09:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fans not right
Sounds like someone has straight wired the fan to run always - I'd look at wiring at the fan relays for post-production wiring.
There should only be one CTS on the inatke either on or near the thermostat housing.
The driver side "sensor" is actually just a sender for the temp guage, and has nothing to do with fan operation.
On the pass side, on the head, between #6 and #8 spark plug is the fan switch, which controls the secondary fan - the primary fan is controlled solely by the computer through the CTS on/near the thermostat housing.
Old Aug 28, 2011 | 08:09 AM
Re: fans not right
the wiring is back to factory when its doing this so i have have 2 things broken?
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
