Normal cooling system operation and temps.
Old Aug 28, 2011 | 01:16 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
It's a 305 TPI.
My pressure cap is 16. 50/50 mix, 195 thermostat.
While driving, my car is around 198*, according to my scantool. Temp gauge works, but isn't 100% accurate. Sitting, it climbs above 200.
I did replace my fan switch because the old one literally just fell apart. I've been told my secondary fan should come on around 234-8*.
Can someone explain to me what normal op. temperatures and fan cycles should be on this? I will probably have to sit at the DMV tomorrow morning and want to make sure it is not going to overheat while waiting in line.
Old Aug 28, 2011 | 02:11 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Normal cooling system operation and temps.
220
Old Aug 28, 2011 | 03:15 PM
Mr Froman's Avatar
So is it normal for it to climb higher than that while sitting?
Old Aug 28, 2011 | 03:43 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
When you are driving, cooling will be at it's best. When sitting, it takes some time for the temp to build until the fan(s) come on. True, the stock secondary fan comes on at 238*. I recently changed to a secondary switch that comes on at 211* and the fans come on earlier when in traffic. Switch is Standard Motor Products part# TS85.
Another impotant thing to check is the rad fins. I assumed that since the A/C condenser fins were clean, that the rad would also be clean. When I removed the rad I was surprised to see that there were 2 circles, the exact shape of the fans, completely stuffed with fluff and grass. Make sure the rad is clean.
Old Aug 28, 2011 | 04:09 PM
Mr Froman's Avatar
Sweet, I like the idea of the lower temp. switch. My rad is new, condenser looks acceptable. No debri, just old looking.
I'm assuming the primary fan is on the left and the secondary on the right (when facing motor)?
I'm going to start my car and let it sit to see if both fans come on. I'm really just mortified at the idea of doing heads again with my daily driver.
Old Aug 28, 2011 | 07:02 PM
Mr Froman's Avatar
Sorry for double post. Ran my car, drive w/ chocks and e-brake and it would go up to about 228, fan kicked on and back down to 218. Everything seems to be okay
Old Aug 28, 2011 | 07:23 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Driver's side - primary
Passenger's side - secondary
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
