A/C on Overheating problem
Old Aug 28, 2011 | 02:24 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
I have searched this thread and tried everything. Only thing i can think of is coolent does not have enough time in radiator. 160* thermostat with 160* fan switch. When my ac is on the car will overheat on the highway. air dam is fine. radiator is new. And of course at idle it will overheat (240) with a 160* thats overheating to me. is there after market fans i can use that work with these cars?
Old Aug 28, 2011 | 03:37 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Re: A/C on Overheating problem
You are correct a 160 Thermostat will not give the radiator enough time to cool down the coolant when outside temps are high. I have found the 180 works great in both winter and summer (even though a 170 is offered). I have found the dual fan set ups found in 2001 and newer Old Intrigue's work great. They bolt right up to the radiator so be sure you pull the top and lower mounting hardware and keep the bolts from the radiator when you pull the fans. A little trimming of the shroud is needed and this can be swapped in and will take a few hrs to do. These fans use the same pig tail as what is in your car now so no electric work is required. I pulled the nut out when I drilled through my radiator and then installed the nut and drove the bolt in.
Old Aug 28, 2011 | 05:42 PM
one92rs's Avatar
Car: SOLD!!!!!
4th gen fans work great on our cars. put a higher thermostat in that car also.
Old Aug 30, 2011 | 09:15 PM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
alright guys thanks, ill be swapping out the therostat soon. now what about the switch. should i go to a 180ish switch also?
Old Aug 30, 2011 | 10:55 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
You might want to get a Airdam if you don't have one. I went through trying to replace everything to fix my over heating problem. I got a Airdam and it's fixed. I live in Az and we have hot temps. Works great with the AC on high for hrs. No over heating. You might want to give it a try before tearing out the thermo. Good luck
Old Aug 31, 2011 | 11:05 AM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Originally Posted by CamKid1992
I have searched this thread and tried everything. Only thing i can think of is coolent does not have enough time in radiator. 160* thermostat with 160* fan switch. When my ac is on the car will overheat on the highway. AIR DAM IS FINE. radiator is new. And of course at idle it will overheat (240) with a 160* thats overheating to me. is there after market fans i can use that work with these cars?
I mentioned that my air dam is in perfect shape.
Old Sep 4, 2011 | 06:50 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
how is she running ?
my86bird
Oct 23, 2015 12:20 PM
greenyone
Sep 2, 2015 03:39 PM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
