Cooling Problem
Old Aug 29, 2011 | 07:07 PM
dunkirk's Avatar
Cooling Problem
89 305 converted to carb, New Rad, Thermo 160, Hoses, have by passed the heater!
Airdam good and no obstructions with Rad- Compressor. Hard freeway will get it boiling over and have flushed the motor several times and it is clean but after running a while the Coolant turns brown again??
Thinking I've got a cracked Head, although Oil does not seem to be contaminated?? Coolant does not seem to be disappearing??No white smoking out of exhaust
Other then that timing good and gas mileage is between 18 to 21MPG???
Any thoughts on the matter before I tear the Heads off?????
Old Aug 29, 2011 | 07:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Cooling Problem
http://www.carnut.com/ramblin/_cool3.html
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
chazman
Aug 22, 2015 02:01 PM
