heat by my feet
Old Aug 30, 2011 | 09:30 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
heat by my feet
hey i have an 85 iroc and when i drive it after awhile it starts to be warm by my feet, its not intense or anything but it does get the car warm after a minute. i have the heater unplugged from the blower motor so the heat isnt functional right now. could it be my heat shield is bad or something? btw I dont have headers or anything its all stock. any ideas would be helpful.
Old Aug 30, 2011 | 09:42 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: heat by my feet
If you have dual cats, your heat shield could be rotted away or not there at all. Climb under and give it a look.
Old Aug 31, 2011 | 05:53 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: heat by my feet
do you feel heat from the floor or do you feel heat blowing out onto your feet?
Old Aug 31, 2011 | 09:38 AM
GreenieG's Avatar
Car: 1985 IROC-Z
Re: heat by my feet
a combination of both
Old Aug 31, 2011 | 10:06 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: heat by my feet
you only need to disconnect the yellow wire at the heater motor to stop it from blowing all the time.
Old Aug 31, 2011 | 10:22 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: heat by my feet
is your temperature slider on your ac control set to warm?
Old Aug 31, 2011 | 08:14 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Re: heat by my feet
i have my heater unplugged because i have my engine fan wired to my blower motor untill i get around to getting a new heat sensor. so i always have the slider on my control set to high so the fan will stay on.
Old Aug 31, 2011 | 09:31 PM
GTA_Notch's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 5.7 TPI
Axle/Gears: 3.27 9 Bolt Borg-Warner Posi
Re: heat by my feet
If you feel hot air blowing on you, the first thing I would check is for holes in the firewall. It might be coming in through one of the little rubber grommets. Especially as the air under the hood heats up, expands, then looks for somewhere to go. At speed the hot air probably gets pushed through whatever gap is around the wires.
Pop the hood and take a look to the right and below the brake booster. In my 'bird there's a grommet right around there. I'm pretty sure my S10 daily driver has a similar issue blowing hot air at my feet. If I ever get around to it, I might cover the hole with some tape. Preferably silver with some heat reflective properties. You could also use clear silicone or just regular duct tape.
Old Aug 31, 2011 | 11:53 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Re: heat by my feet
okay ill check the firewall tomorrow then. i currently do have a jack or anything its gonna be hard to get under it for a while.
Old Sep 1, 2011 | 06:14 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: heat by my feet
I have an 84 T/A and it does the same thing. I've done some research and asked a few questions as well. The best I've been able to determine, is that since the older cars don't have the heater bypass valve in the heater hose which allows warm water to constantly flow through the heater core. As air comes into the cabin through the fresh air vents it runs across the heater core and warms up causing your feet to get hot. How accurate this is, I don't know, but as I mentioned earlier, it'st he best I could figure out.
Old Sep 2, 2011 | 04:08 PM
ta6point6's Avatar
Re: heat by my feet
My car does the same thing
Old Sep 2, 2011 | 04:10 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: heat by my feet
mine does too but only from those vents on the center console..can only feel it in shorts tho so its not that bad
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
ironbmt
Sep 27, 2015 06:00 AM
