Over heating!
Old Sep 11, 2011 | 11:45 AM
stephen15935's Avatar
Over heating!
i have a 1982 trans am/ firebird. what ever you want to call it. 5.0 crossfire injection
just got it, over heated since day one. pulled thermostat come to find out that it was "gutted" replaced it with a new one. care over heats real quick now, with in 5 minutes or so id say of just idling.
replaced the radiator, old one was shot.
hooked it all up and BAM, same thing. trying to get the air out, filled up the resvior and started engine with the rad cap off, did so until the coolant came pouring out.
heater hose and bottom rad hose are hot but the upper is not.
any ideas?
Old Sep 11, 2011 | 08:54 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Over heating!
I'd say that the thermostat is stuck shut. Make sure that you have the correct one and its installed right. Also could be just a bad one right out of the box. You can pull it out and put it in a pan of boiling water on the stove to see if its opening.
Old Sep 12, 2011 | 08:10 AM
torque_is_good's Avatar
Re: Over heating!
any ideas?
the top hose gets hot once the thermostat opens and the waterpump is functioning. Since you had no thermostat, and the hose was not hot, then the water is not flowing.
sooooooooo, what circulates the water??????? (you know the answer to that)
take the rad cap off, start the car, look into the radiator and see if there is circulation going on and it should be brisk. I'm not talking sloshing because of engine vibration.
Old Sep 13, 2011 | 01:12 PM
Re: Over heating!
put the thermostat in boiling water, it does work, now that i have the thermostat out it does not heat up as fast (of course). i can run my car for about 20-30 mins now before it will over heat. so that problem occurs when i put in the thermostat and it will not open.
could this be from the guy before my putting a reverse pump water pump on it?
Old Sep 13, 2011 | 01:39 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Over heating!
wire fan to a switch to run all the time, and make sure you have a good air dam for driving cooling.
Old Sep 13, 2011 | 08:25 PM
jermdm's Avatar
Car: 1989 Iroc-z
Re: Over heating!
If the guy before you put a reverse water pump on that engine, I would say that would be the problem. That engine should have a standard rotation water pump on it. Make sure you have the correct water pump on it.
Old Sep 13, 2011 | 11:09 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Over heating!
I would check the waterpump.
Old Sep 14, 2011 | 04:27 AM
oif0709's Avatar
From: http://www.facebook.com/ThirdGenCamaroFirebird
Car: 1987 Camaro Z28
Re: Over heating!
Definitely the reverse water pump. Go pick up the normal one and you will fix your problem.
Old Sep 14, 2011 | 08:33 AM
Re: Over heating!
and, if that doesn't resolve the issue then the OP needs to completely flush the engine several times and refill with 50/50
if the problem still exists then he has internal blockage
Old Sep 14, 2011 | 12:38 PM
oif0709's Avatar
Re: Over heating!
I agree.
Old Sep 17, 2011 | 02:08 PM
tweed's Avatar
Re: Over heating!
Hi all i always have a hard time trying to figure out where to make a new post so im dont mean to **** block,pun not intented.if someone could let me know where t post for my 86 trans am thank you.
Old Sep 17, 2011 | 06:04 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Over heating!
When you click on to the cooling board look at the red, white, and blue rectangle in the upper left corner that says "new thread", click on it and have at it if cooling is your question. Same deal for any section you need answers on
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
