Cooling flush with CLR
Old Sep 18, 2011 | 07:20 PM
91camarolt1's Avatar
Car: 1991 chevy camaro rs
Engine: 5.7 cid Lt1
Axle/Gears: stock
Is it possible to use this for flushing out the deposits in the cooling system. Has anyone tried this. I thought about using this. I just want to get some feed back on this topic before i try it out.
Old Sep 18, 2011 | 09:17 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Cooling flush with CLR
I guess it would work, but why not just use rad flush?
Old Sep 19, 2011 | 06:41 PM
Engine: 5.7 cid Lt1
Axle/Gears: stock
Just trying to save a few buck. I have CLR here at home already. So I had the idea of using it. I was just curious. Thank you.
Old Sep 20, 2011 | 11:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
CLR will eat all the soft metals in your cooling system.
Old Sep 20, 2011 | 11:38 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
What's the best way to get all the coolant passages in an older block and heads cleaned out?
Old Sep 20, 2011 | 11:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use a radiator flush product that doesn't use a strong acid.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
