blockage somwhere
Old Oct 2, 2011 | 03:53 PM
stephen15935's Avatar
blockage somwhere
i have a 82 trans am with a 5.0 cross fire injection.
it currently has a new radiator, water pump and a stat.
it t over heating and i can think of what else it could be but a blockage in the block somewhere.
any tricking on finding it and removing it? the upper rad hose stays cold and my lower and heater hose gets hot.
Old Oct 2, 2011 | 07:35 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: blockage somwhere
if your upper hose stays cold thats an indication that the tstat isnt opening. take it out and drop it in a pot of nearly boiling water and see if it opens. did you get the reverse flow water pump or the standard flow?
Old Oct 3, 2011 | 12:23 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Make sure you put your T- stat in the correct way as well.
Old Oct 3, 2011 | 06:17 PM
one92rs's Avatar
Car: SOLD!!!!!
remember to bleed the cooling system to get the air out.
Old Oct 9, 2011 | 03:34 PM
I guess I have a bad head gasket
Drilled a hole in the stat and now runs at operating temp
it kept air locking itself
Old Oct 9, 2011 | 03:36 PM
travis401's Avatar
Car: 91 Camaro RS
it could be that your tstat just isnt opening, did you ever verify that it was by placing it in a pot of boiling water?
klumb15
Mar 4, 2005 11:13 AM
Bjorn
South East Region
May 9, 2004 04:33 PM
PyRo9862
Nov 11, 2003 05:25 PM
abdul hallenger
Oct 15, 2003 05:05 PM
PIMPINPHIL
Oct 5, 2002 11:22 PM
