heater on economy or air cond for heater?
Old Oct 18, 2011 | 07:29 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
which is better for the heater to run on in the winter? the reason i ask is because if i have the heat on economy it pulls air through the cowl and you can hear it when near the outside of the car and its loud, but it doesnt seem like air conditioning does that, so what can i use or can i use both?
Old Oct 18, 2011 | 07:43 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: heater on economy or air cond for heater?
When you have it set on max, the air door to the outside is closed (same as recirculate).
Economy prevents the A/C compressor from coming on.
When you set it on defrost, the compressor also comes on.
In the winter, if it's cold enough, the compressor will not come regardless of setting until the underhood temp gets high enough to raise the pressure.
So go ahead, put the selector wherever you like. But heat works best when it comes out the bottom, which is the economy setting.
Old Oct 18, 2011 | 07:47 PM
Engine: L31 350
so say i put it on economy till it gets really warm in the car then switch over to air conditioning, would that be ok?
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
scotrans am
Sep 5, 2015 04:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
