Coolant Sender Thread Size
Old Nov 26, 2011 | 12:06 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
I didn't think I was this stupid! I'm trying to rehook my factory temperature gage in my 305. P.O. installed aftermarket gage with a nipple in the block. New coolant temp. sender doesn't thread into the nipple and is way too small for the block. Sender is correct (1 wire), and I know where it goes (between 1&3), what do I need to get? Could DRYSEAL or NPTF threads be the problem?
Old Nov 26, 2011 | 07:45 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Coolant Sender Thread Size
Maybe it was a cheap Chinese metric thread set up? A trip to Ace ought to set you up. No adaptor should be needed for a stock sending unit in a stock head. Are they aftermarket heads?
Old Nov 26, 2011 | 10:19 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Old Nov 26, 2011 | 10:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
its npt but I can't remember what size.
Old Nov 27, 2011 | 02:04 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Stock GM cylinder head holes (and senders) are 3/8" NPT. Aftermarket heads like Holley's can have 1/2" NPT.
Aftermarket senders can be 10mm or 12mm
Old Jan 1, 2012 | 01:06 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Different heads--1/2" Thanks!
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
