no heat?
Old Dec 10, 2011 | 04:26 PM
slowoh5's Avatar
no heat?
I just recently changed my thermostat out (car over heated) and now my heat barely throws out any heat the blower sends out mildly warm air I burped the system and it didn't seem to help. I was thinking it could be the heater control valve..... Were would it be located on a 91 l03? Thanks
Old Dec 10, 2011 | 05:50 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: no heat?
heater bypass valve is located right next to the engine on the passenger side.
what temp tstat did you install? and you said you burped the system. how exactly did you do it?
Old Dec 10, 2011 | 05:52 PM
slowoh5's Avatar
Re: no heat?
I got a 195 oem tstat I ran the radiator with it open for a while and let the stat open and close and filled it up with water
Old Dec 10, 2011 | 05:55 PM
travis401's Avatar
Car: 91 Camaro RS
Re: no heat?
run the engine with the rad cap off until the tstat opens, then fill to the top with water and put the cap on. letting the tstat close before filling defeats the whole purpose.
Old Dec 10, 2011 | 06:52 PM
slowoh5's Avatar
Re: no heat?
I've never switched one out anything I should know before I attempt to swap it out?
Old Dec 10, 2011 | 07:02 PM
travis401's Avatar
Car: 91 Camaro RS
Re: no heat?
the heater diverter valve? you just unhook and hook everything back up. chances are its not the problem.
Old Dec 10, 2011 | 07:05 PM
slowoh5's Avatar
Re: no heat?
Then what would be the problem?
Old Dec 10, 2011 | 07:09 PM
travis401's Avatar
Car: 91 Camaro RS
Re: no heat?
most likely low coolant level. the heater diverter valve only restricts the flow of water to the heater core when you turn the ac to cold. if it malfunctions it doesnt do anything when you turn the ac to cold and the ac blows just a tiny bit hotter than normal. with you getting only a luke warm air it points to either low coolant, or an obstruction in the ac box under the dash.
your fan blows full speed right?
Old Dec 10, 2011 | 07:10 PM
slowoh5's Avatar
Re: no heat?
Yes it blows full speed.
Old Dec 10, 2011 | 07:14 PM
travis401's Avatar
Car: 91 Camaro RS
Re: no heat?
then id double check the coolant level by leaving the cap off and running it til the tstat opens.
Old Dec 10, 2011 | 07:29 PM
slowoh5's Avatar
Re: no heat?
Lol I did that all ready its slap full of coolant
Old Dec 10, 2011 | 07:44 PM
travis401's Avatar
Car: 91 Camaro RS
Re: no heat?
then you either have an obstruction in the ac box or an obstuction preventing decent flow to the heater core.. apply full vacuum to the heater diverter valve and see if it gets any better
Old Dec 10, 2011 | 08:09 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Re: no heat?
Did you have heat before?
Old Dec 10, 2011 | 08:32 PM
slowoh5's Avatar
Re: no heat?
Yea I had heat before just changed the valve and it didn't make a difference.... How do I apply full pressure to the valve?
Old Dec 10, 2011 | 09:21 PM
91 Droptop's Avatar
Re: no heat?
You may have an air-lock
turn your heater on, with engine running, keep adding water as air is displaced...have the cap of radiator out...naturally do so with a cold engine..keep running your heater at max. and just keep adding water at radiator..after several minutes all air will be out..you will notice that bubbles will stop and water will look calm at top of radiator orifice..good luck
Old Dec 10, 2011 | 11:18 PM
slowoh5's Avatar
Re: no heat?
I'll mess with it more tomm ill post the results. Thanks everyone for the help thus far.
Old Dec 11, 2011 | 10:01 AM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Transmission: Newly rebuilt 700R4
Re: no heat?
My heater control valve connections cracked open due to age a few weeks ago. The symptoms were no settings on climate control (every thing was Defrost, max, norm, htr, vent)
Old Dec 11, 2011 | 12:10 PM
slowoh5's Avatar
Re: no heat?
Ok so I ran the heat with the rad open...and let the retarded open it burped and filled it back up with water....still only semi heat. I'm totally lost on what to do.
Old Dec 11, 2011 | 05:42 PM
travis401's Avatar
Car: 91 Camaro RS
Re: no heat?
you might have a blackage somwhere. under the dash and pull the ac box cover off and take a look(its not that hard). you can also tell if the heater core is getting hot.
Old Dec 11, 2011 | 05:45 PM
slowoh5's Avatar
Re: no heat?
Guess ima replace the radiator core next weekend.
Old Dec 12, 2011 | 02:49 PM
slowoh5's Avatar
Re: no heat?
I think my problem was solved when I got home from work I decided to back flush my heater core when I did that I saw some nasty brown stuff fly out the hose I flushed it a few more times until it became clear. My heat is working decent now. I think a radiator flush is in my near future even though it looks like a newer radiator.
Old Dec 12, 2011 | 05:02 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Re: no heat?
A radiator flush is always a good idea imo. When i got my Formula the antifreeze was ORANGE from rust!!! No telling how old it was.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
