Temperture Gauge On Dash Not Working
Old Dec 13, 2011 | 07:40 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
Ok i just got a iroc a few days ago,the guy I bought it from says the car doesn't overheat and he has the fan hooked up to a toggle switch and says he just rides with it on all the time but i would still like to know what my temp is while driving .... what could be causing the temp hand to not read?... Please help guys, I want to get this fixed asap......
Old Dec 14, 2011 | 12:40 PM
dredre08's Avatar
Re: Temperture Gauge On Dash Not Working
Anybody?
Old Dec 14, 2011 | 04:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Originally Posted by dredre08
Anybody?
bad coolant temp sender
Old Dec 14, 2011 | 04:30 PM
dredre08's Avatar
Are those expensive?
Old Dec 14, 2011 | 04:38 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
not at all.
Old Dec 14, 2011 | 04:39 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
check the wiring too. it may just be disconnected or singed. - driver side of engine bay, green wire.
Old Dec 16, 2011 | 05:24 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the coolant temp sending unit will be on the driver side head, between the #1 and #3 cylinders. should have a single green wire hook up to it. id figure out whats up with the fans and fix that. leaving them hooked up to a toggle switch is not a good idea.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
justin57
Aug 20, 2015 07:05 PM
