OEM temperature gage replacement
Old Dec 31, 2011 | 03:27 PM
jbradhill's Avatar
Car: 1986 Camaro IROC Z28
Engine: 383 SBC
Axle/Gears: 3.75 LS
I have a temperature gage that is acting flacky... it works for a while and then stops working. I replaced the temp sending unit and it worked for a while and is no longer working.
I would like to just replace the OEM temp gage, but haven't been able to locate one. Anyone have any recommmendations?
Thanks Brad
Old Dec 31, 2011 | 03:57 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: OEM temperature gage replacement
if you want stock gauges, a junk yard or someone that sells used parts like hawks or third gen ranch is your only options.
or you could replace the stock gauges with aftermarket units.
Old Dec 31, 2011 | 06:16 PM
amlv20's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
ebay, thirdgen ranch, hawksthirdgen.
Out-Cast
Dec 31, 2015 04:40 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
Irocohio
Aug 12, 2015 08:03 AM
NBrehm
Aug 5, 2015 07:57 PM
