Bringing the camaro back on the road, problems?
Old Mar 14, 2012 | 11:14 PM
EVH-SETH's Avatar
Car: Chevrolet Camaro
Engine: 2.8 MPFI v6
I recently purchased a 1987 camaro v6, and im just wondering what might have caused my problem. I was driving home tonight and found that all the sudden i lost power and my engine light came on. After about 2 minutes it went off and all was well. I got home and looked under the car to find half the pipe and the entire catalytic conv. was bright red. I know that i need to replace all fluids, new spark plugs, some anti freeze and just get it over with, but could that be something more? Should i replace the o2 sensors, cooling system etc.? Like i said im new to camaros and i wanted to know for a car thats been in a garage for probably years, and for it to be brought back out on the road, what should i do to get it back to pristine running condition?
Thanks,
my first post btw
Seth
Old Mar 14, 2012 | 11:16 PM
EVH-SETH's Avatar
Engine: 2.8 MPFI v6
Re: Bringing the camaro back on the road, problems?
realize this should have been in the Tech/Engine thread that helps with problems like these. Apologies
Old Mar 14, 2012 | 11:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A glowing converter is usually a sign that you're blowing raw fuel into your exhaust which then ignites in the converter and overheats it. Your catalyst bed is a heap of molten slag now.
Pull the codes and see what the computer was complaining about first.
Old Mar 14, 2012 | 11:30 PM
EVH-SETH's Avatar
Engine: 2.8 MPFI v6
Where would be the best place to take it? Live in a small town.
Old Mar 14, 2012 | 11:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Take it for what?
Old Mar 15, 2012 | 12:19 AM
EVH-SETH's Avatar
Engine: 2.8 MPFI v6
I dont know what you mean by codes. Ive never been taught this stuff dude. hahaha. Do i take it to a shop and they hook it up or what?
Old Mar 15, 2012 | 10:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You do it yourself with a paperclip. Searching will turn up a few hundred threads about it.
Old Mar 15, 2012 | 10:58 AM
Zaar's Avatar
Car: 1988 Iroc-Z tpi 5.7
Engine: ls2
Transmission: 4l80e
Axle/Gears: 3:42
i was going to tell you to beat the converter internals out but i might get slayed by someone on here lol!
Old Mar 15, 2012 | 05:50 PM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
No, you don't need to take it in to have anyone scan it. You can do it yourself, simple.
https://www.thirdgen.org/service-eng...ht-error-codes
Seriously, just take a paperclip and short out the two pins, and count the flashes. Since you have an '87, it might be pin 6 and 12. Anyway, just read the tutorial from the above link. It's rather simple.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
