Standard or Reverse Flow
Old Apr 12, 2012 | 10:33 AM
bombrcar's Avatar
Car: 1992 RS
I have a 92 RS with the 305, AC and PS with a single serpentine belt.
The water pump is leaking and I was going to pick one up on the way home today, but have come across the fact that there are standard and reverse flow water pumps. All I have found so far is that you have to look at the water pump and see which way the belt goes around the pulley. But since I don't have the car with me, does anyone know if there which one I might have?
Thanks!
Old Apr 12, 2012 | 12:58 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Standard or Reverse Flow
i would guess its reverse flow. if your car is stock, just order the correct pump.
Old Apr 12, 2012 | 01:50 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, the serpentine models use the reverse rotation pumps
Old Apr 12, 2012 | 02:49 PM
bombrcar's Avatar
Car: 1992 RS
Thanks for the responses! Much appreciated!
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
Bigold4x4
Sep 28, 2015 05:21 PM
