sensor
Old Apr 25, 2012 | 12:22 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
sensor
which sensor is this inthe pics is on the cylinder head on driver side
Old Apr 25, 2012 | 12:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: sensor
Fan switch
Old Apr 25, 2012 | 03:08 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: sensor
Dose it have a clip that you push on from the side .One shaped like this "U" ? Just curious because I have one like that.
Old Apr 25, 2012 | 03:24 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: sensor
that is what i tought it was that why my fan did not come on. it is fix now. thanks
Old Apr 25, 2012 | 08:17 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: sensor
Temp sender for your gauge, not for the fan.
Old Apr 25, 2012 | 08:56 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: sensor
This is correct.
Old Apr 25, 2012 | 10:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: sensor
I could have sworn it said passenger side the first time I read it.
Driver side is the gauge sender.
Old May 1, 2012 | 09:50 AM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: sensor
Yep,thats the temp sensor.ussally is screws into the thermostat housing, Had to replace mine and the pigtail. Hard to find the pigtail with the yellow and black wire.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
