location of temp gauge sender
Old May 4, 2012 | 05:19 AM
djjon76's Avatar
Car: '84 Trans Am
Hi all.
Does anyone have a photo of the location of the temp sender?
Its on a '84 t/a 5L.
Cheers.
Jonno.
Old May 4, 2012 | 05:40 AM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
Re: location of temp gauge sender
I don't have a pic, but I also have an 84 T/A. The temp sender is located on the driver's side, directly underneath the stock exhaust manifold, between the first and second spark plugs from the front. There should be a single wire clipped on it.
Joe
Old May 4, 2012 | 09:09 AM
djjon76's Avatar
Car: '84 Trans Am
Does this look like where it is supposed to be?
Old May 7, 2012 | 09:01 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
that looks like where joe is talking about, and it looks like where i have my after market gauge hooked in. my factory gauge is pluged into a sending unit next to the thermostat housing.
Old May 7, 2012 | 10:31 PM
djjon76's Avatar
Car: '84 Trans Am
Cool. The aftermarket one that is currently on the car (a mechanical one) is in the thermostat housing water neck. Is it worth installing a new one in the old location, or just replace the mechanical one with a proper sender?
Old May 8, 2012 | 08:57 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
i have the after market gauge in the head because the temp there is critical on a 400 sb. as long as the sending unit is for your gauge you should be fine...hopefully if im wrong somebody will let us know.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
