Hardly any a/c pressure
i have an 86 camaro and my problem is that my cold and hot air seemingly has zero pressure unless im on the freeway. even then as if its just forced air. You cannot hear air blowing but you can hear the channels changing when you set the settings from say heater, to cabin, to passanger. Wtf is it?
Thanks, TayTayMurphy
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Hardly any a/c pressure
sounds like you are only getting ram air-blower not
working,quite a few causes for that-anything from
blown fuse to bad blower motor.
