Cooling.
Old Jun 4, 2012 | 01:27 PM
Holliman48's Avatar
Car: 1985 Trans Am
Engine: 305 TPI 5.0L
Cooling.
So my car overheats very quickly if I don't have my heater on. If I have my heater full blast and I obey the speed limits it stays at 220 for a while. This used to never be a problem. Anyone have an idea why this is? Also did a radiator flush to get most of the rust out of my block. 3 Days later it's full of rust again. I'm stumped.
I was also thinking about getting a low temperature fan switch. I heard they make this so your fan will come on much earlier. But I can't seem to find one. Could someone point me in the right direction?
85 T/A 305 TPI
Old Jun 4, 2012 | 06:27 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Cooling.
might take several flushes to get all the rust out of the
cooling system;after i swapped a used '84 vette engine
into my car i had to flush it 4 times to get the coolant
to stay green IF you can get the block drains/knock
sensor out,you will get a better flush as settled rust
will drain out better.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
dennisbernal91z
Fabrication
28
Jan 17, 2011 01:17 PM
TurboDiverArt
Jan 22, 2007 09:06 PM
FatOne
Apr 21, 2002 01:42 PM
